+2 a-arms and shocks
Rapture
Bit of a noobish question but ...
Im thinking of buying some fulflight +2 a-arms ... will standard Banshee shocks be ok to use with these?
I want to go a bit lower as well so im not sure whether to stick with the stock a-arms and buy the blocks which mount the shock further out or get +2 arms with shorter shocks (and if so, which shocks?)
Any advice appreciated.
Yes stock length will work but an aftermarket shock setup for the +2+1 will work even better, I may be interested in selling a set of works shocks that are 14.5", stocks are 14.75" it does lower the front end
Are there any shocks from other bikes (eg YFZ450) with will bolt straight on which will lower my Banshee? Im on a bit of a budget right now so i cant splash out on top gear just yet.
Cool, you probably will have to just go for a standard length shock if you want to go off-road with it as well.
I've fitted r6 shocks to mine which lowers it a lot, it's stiff as he'll though. I've contacted a guy though who sells softer springs and will probably get some soon.
 Nice. You got any pics of your Banshee on R6 shocks?
