What and where to get Servals cylinders
I don't know much about the aftermarket available of cylinders. I'm looking for something closer to the stock bore versus going big. How many bore sizes are available and where can you get a set? Are servals a product by cub? Like I said I'm not sure who owns what and who makes what and what its called.
If your going to keep stock bottom end I'd just port your stock cylinders and head mod. I wouldn't spend the money for a stock stroke serval. A good ported set of cylinders , head mod, timing plate and reeds will get you mid 60's easily.
If you want to get a crank and other supporting parts then a serval will far surpass stock cylinders.
Ok, How much am I looking at for a set of stockers ported for 60+ HP. The cylinders that are on now have damage to them. The bridge between the boost port and main port is gone. It still runs well and pulls hard but it won't last forever. I need to start searching for a good replacements that will hold up to the abuse I take out on them.
