Aftermarket cylinders
Do you mean in bore size also? There are stock stroke cub cylinders that i know of. Pretty sure i remember seeing these in a 66mm may have even been 65mm bore wich was quoted as an old style. I know most are 68mm now
Not so much bore size. I don't want to have to change any other parts like the head or exhaust. I would like to keep everything else the same.
One of my cylinders has a bridge missing between the boost port and main port. It ran last year with no problems like that. However I would like to have another set ready to go if and when it fails. So either I have to pull mine off and get them re-sleeved or buy another set and port them and paint them and so on.
I can get another set of cylinders for around $200 plus $80 for bore on ebay. Re-sleeving will cost $350~$400 depending on what sleeves are chosen.
Or I can just spend more on a nice aftermarket set thats already ported and proven.
Edited by turbowrenchhead
For what you have and the riding you do….as Stock stroke Serval top end kit would be the hot ticket.
You could run all your existing parts with nothing to change but your domes. Your carbs and pipes will work fine.
Thanks John.
Is Serval a cub? Are there different bore sizes? I don't want to go to big of displacement because of the longer trail riding I do. I'm already the first guy to run out of gas running with the 4 stroke's. Who's got a good deal on a set?
I'm able to hang so far with the stock tank and the six pack rack 2.5 gallon reserve with a dune/race port on the cylinders. There is no way in hell I'm buying a 4 poke for trail riding. My 4 poke plows snow and drags shit.
That 5 gallon tank they make for the banshee looks terrible. Plus it restricts your turning radius. A friend of mine put one on and he had to install a 6" handle bar riser to get any kind of turning radius. IMS makes a nice looking 4 gallon that I will end up buying down the road.
Ive been wanting to go bigger on the motor myself butvthe damn fuel milage...we do some 50 mile trips through the woods and im good for 50 but im stock stroke stock ports...but im feeling the itch to go bigger...fuel is what the SxS are for!
