uman1030 Posted March 5, 2014 Report Share Posted March 5, 2014 honestly i havnt installed vf4's I had jeff at fast do this with my build, so i dont have much advice other then look over the mating surfaces make sure they are nice and flat and make sure there is no left over gasket on the cylinder. Inspect the gaskets for tears and such. I would think some rtv would be fine if needed to get a seal but ive never had to use it in this area personally Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted March 5, 2014 Report Share Posted March 5, 2014 Use a mm or 64ths scale on the surfaces. If there are any gaps this will make it very obvious. This is highly unlikely but worth a look Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 8, 2014 Author Report Share Posted March 8, 2014 I got it all sealed up. It held 6 psi for 10 minutes. I installed the the 30 pilot and 340 main left the needle on the middle clip. Put everything back together. It idles good, but the throttle reponse doesn't seem like it snappy. Could it be the rings aren't seated yet? I'm going to re-torque everything in the morning. Sorry for the Delayed reponse life's been getting in the way haha Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 8, 2014 Report Share Posted March 8, 2014 Have you tried adjusting the A/F screws to see if that helped throttle response? what are they set at now? 340 seems pretty rich for your bike. The 300 you had in should have put you pretty close depending on outside temperature. What was your compression with those 20cc domes? What type of fuel are you running? Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 8, 2014 Author Report Share Posted March 8, 2014 I've played with the air fuel screws. I have them set at a half turn out. The 340's were recommended by Jeff from fast. As a starting point for cold weather 160# in both cylinders Fresh 93 mixed at 32:1 with maxima 927 oil Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted March 8, 2014 Report Share Posted March 8, 2014 I've played with the air fuel screws. I have them set at a half turn out. The 340's were recommended by Jeff from fast. As a starting point for cold weather 160# in both cylinders Fresh 93 mixed at 32:1 with maxima 927 oil I would back them out more. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 8, 2014 Report Share Posted March 8, 2014 ↑ agree with this 1/2 turn out seems too rich on the A/F screw with a 30 pilot installed. Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 8, 2014 Author Report Share Posted March 8, 2014 It's fixed took it to my neighbors he gave me a hand. It ended up being the parking break being disconnected from the handle bar connection. It runs sweet just gotta fine tune it and put the tors delete on Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 9, 2014 Report Share Posted March 9, 2014 It's fixed took it to my neighbors he gave me a hand. It ended up being the parking break being disconnected from the handle bar connection. It runs sweet just gotta fine tune it and put the tors delete on unplug that switch at the connector Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 9, 2014 Author Report Share Posted March 9, 2014 I did unplug the tors connector from the box. I already ordered the the tors delete kit so that'll be tomorrow's project Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 9, 2014 Report Share Posted March 9, 2014 I was talking about the parking brake switch thats on the clutch lever. unplug it and toss the switch. Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 9, 2014 Author Report Share Posted March 9, 2014 It doesn't run right with out the parking brake switch plugged in. It was unplugged we were checking the wires buy the stator. Revving it then he grabbed it pushed the sensor in and it started running good Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted March 9, 2014 Report Share Posted March 9, 2014 It doesn't run right with out the parking brake switch plugged in. It was unplugged we were checking the wires buy the stator. Revving it then he grabbed it pushed the sensor in and it started running good That means that wire is grounding out somewhere Quote Link to comment Share on other sites More sharing options...
89mustang Posted March 9, 2014 Author Report Share Posted March 9, 2014 Oh. Thank you ill check that out Quote Link to comment Share on other sites More sharing options...
