How To Fit Stock Airbox To Single Carb.
fast87
Hey, first i took a stock airbox i bought for 18 bucks from trayfoe, stuck it in with the front plate unbolted, and started cutting around the opening, i basically cut the whole front part off it flush with the sides of the box except for the mounts on each side. which the plastic i cut wider as it got closer to the box for strength...cut the bottom out for the bowl, and it fit, just never use tin snips on plastic like that because whenever u start a new cut it cracks a line in the plastic usually in the wrong direction, i was able to cut away the cracks except 1 which i melted together, anyway it doesn't have a perfect seal, but only about 1/2in. after i clamp the k&n on, by the way this is for a graydon proline setup only, i'm sure it woulden;t work for the trinity setup because it is much shorter, hope this helps somebody out since the rainy season is here, later.
~Mark~
