hoppedupandcutdown Posted February 19, 2014 Report Share Posted February 19, 2014 Totla weight of a Lonestar axle and Boss 36mm carrier rear assembly compared to a JJ&A play axle, complete with sprocket rotor and lug nuts. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2014 Report Share Posted February 19, 2014 Plus you get a no questions asked lifetime warranty. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted February 19, 2014 Report Share Posted February 19, 2014 Nice post hopp. Pretty cool to see the weight differences Quote Link to comment Share on other sites More sharing options...
lastnline75 Posted February 19, 2014 Report Share Posted February 19, 2014 That is quite a difference for sure! Thanks Dennis. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 19, 2014 Author Report Share Posted February 19, 2014 You're welcome Brian, But I see that I forgot the cotter pins when I weighed the Lonestar... hahaha Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted February 19, 2014 Report Share Posted February 19, 2014 The LSR is steel correct? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 19, 2014 Author Report Share Posted February 19, 2014 The LSR is steel correct? Yes Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 19, 2014 Report Share Posted February 19, 2014 Whoa! Big weight savings. Wish I could get a wider aluminum axle for flat track from them. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2014 Report Share Posted February 19, 2014 Whoa! Big weight savings. Wish I could get a wider aluminum axle for flat track from them. How wide do you need to be? The play axle is 34" long.. With the right wheel offset and the hubs all the way out you could probably be at 42+ inches. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 19, 2014 Report Share Posted February 19, 2014 (edited) Most every one is 48-50. So +4 out back is about 48 with the right rear wheel offset. Edited February 19, 2014 by trickedcarbine Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2014 Report Share Posted February 19, 2014 Most every one is 48-50. So +4 out back is about 48 with the right rear wheel offset. Oh that's quite a bit.. I will look at mine tomorrow and see how wide I can make it. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 19, 2014 Report Share Posted February 19, 2014 Thanks man. Quote Link to comment Share on other sites More sharing options...
Azryll Posted February 19, 2014 Report Share Posted February 19, 2014 Most every one is 48-50. So +4 out back is about 48 with the right rear wheel offset. Am I missing something? If the play axle is 34" and you use +4 off set rims your at 42" Quote Link to comment Share on other sites More sharing options...
possum Posted February 19, 2014 Report Share Posted February 19, 2014 lifetime warranty if you ship the entire setup back for inspection. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 19, 2014 Report Share Posted February 19, 2014 lifetime warranty if you ship the entire setup back for inspection. So? Quote Link to comment Share on other sites More sharing options...
