banshee2sick Posted November 11, 2003 Report Share Posted November 11, 2003 I am splitting the case on my shee, and am planning on putting a new shift cam in while its apart...is there anything other suggestions on improving the shifting ? Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted November 11, 2003 Report Share Posted November 11, 2003 Why are you putting in a new shift drum? I put on the tutors or tudors kit on mine and it shifts real smooth now. Also look at the shift shaft where it moves up and down on the shift star. Check to see if that spring is tight because they are weak and loose their tention quick. Thats about it. You could try a shift star but I have never had one so I couldnt say how good they work. Tudors said that with their kit you dont need one. Also check out the wear of the gears and the shift forks too and port match the case to your cylinders. It is not that hard of a job. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 11, 2003 Report Share Posted November 11, 2003 I havent tested mine yet, but replacing the stock lever with the yamaha factory one + 3 REALLY HD springs for the clutch seems to help the gears engauge smoother but I don't have any real testing on it yet...Im also unsure abotu the shift star mod, I know it helps you to find neutral easier but I think with a good lever and springs the rest isn't needed as bad. Quote Link to comment Share on other sites More sharing options...
banshee2sick Posted November 12, 2003 Author Report Share Posted November 12, 2003 I'm not familiar with the Tudors kit. Where would I look for one? Quote Link to comment Share on other sites More sharing options...
Leadfoot350 Posted November 12, 2003 Report Share Posted November 12, 2003 I think it is tudorsperformance.com? Quote Link to comment Share on other sites More sharing options...
boonman Posted November 12, 2003 Report Share Posted November 12, 2003 I think with a good lever and springs the rest isn't needed as bad. Have you seen a stock vs. modded star? It is a definite plus. Quote Link to comment Share on other sites More sharing options...
H300F Posted November 12, 2003 Report Share Posted November 12, 2003 You can put in Rz shift forks, cut your gears dogs (2-5 or 6), switch shims around, mod your shift star, or do an override. PM banshee370 about cutting the gears, he has a website all about it. It stops missed shifts where you find a false neutral and is not a drag only mod it is great for all riding. I didnt get to cut the gears this time around because of time and money, but I did put in rz forks and switched the shims. Quote Link to comment Share on other sites More sharing options...
raxen Posted November 12, 2003 Report Share Posted November 12, 2003 Just go for the RZ shift forks and shift star mod. Just got mine back and running, great stuff. Quote Link to comment Share on other sites More sharing options...
