Idle increases when idling?
mossontte
irractic idle is a lean condition, sometimes bad reeds can make idle wacky too. lean could be caused by an air leak or just too small of a pilot. could be running out of fuel too, clogged idle circuit, float level too low etc..
Brand new reeds, #25 pilot air jets float is within range per clymer manual.
Think I should bump up to 27.5 pilot?
Stock airbox and pipes? If not then then pilot is likely the problem. Have you tried turning in fuel/airscrew to see if you can richen it up to stabilize the idle?
you can delete all your double posts. Vf4 reeds like a very fat pilot. that is your issue. Get rid of the boost bottle it will just tear your boots and does nothing for performance.
27.5's fixed her all up!!!! One side is smoking more than the other? Couldn't seem to get it with the air/fuel screw.. Any suggestions?
