35mm pwk a/s needle
uman1030
trying to order some odds and ends parts for my Fast 421 serval, hasnt arrived yet but i want to be prepared to just put everything together and start tuning. looking over my 35mm pwk  airstriker carbs they have 48 pilots 152 mains and CGL needles that were on the 2nd clip. i thought these came off a 421 cub but i cant remember now.
I hear most people refer to the CEL or DEK needles any advice on wich ones i should start with or will these be easily tunable as well.  plan on buying a range of jets up and down from whats in it so i have it all on hand to fine tune.
Also any one know what size the overflow hoses are and also the fuel line and where i can purchase it. Will i need a dual pingle to feed these? what about the gas cap should i hog it out to vent better.
also the part number S65A2 on the carb indicates it is a 35mm A/S according to http://www.sudco.com/pwk.html but when measuring the inside bore diameter of the engine side of carb it measures nearly 36mm is that normal or have they been bored that large
Thanks sleeper, I may just buy the CEL's when i buy a bunch of jets.
After doing some research it looks like the overflow tubes from Keihin are 3mm I.D. i found some on ebay for cheap also bought 1/4(6mm) tubing for the fuel line and a inline filter. ended up being about $34 with shipping but its enough to fully do both bikes with some left over.
Could some one measure the engine side  bore I.D. of their 35mm pwk and tell me what it is. I assumed it would be 35mm or real cose but mine appears to be 35.97mm yet ive verified they are definitely 35mm pwks by part number.
  • 2 weeks later...
