lmcannon Posted March 2, 2014 Author Report Share Posted March 2, 2014 Well it's all back together and started on first kick. Need to tune the carbs now tho to get it to idle. Quote Link to comment Share on other sites More sharing options...
lmcannon Posted March 2, 2014 Author Report Share Posted March 2, 2014 My rear subframe needs to be replaced or straighted. Quote Link to comment Share on other sites More sharing options...
Denny2424 Posted March 2, 2014 Report Share Posted March 2, 2014 Wow! That's in bad shape. Front end looks out of wack also. Sent from my SM-N900T using Tapatalk Quote Link to comment Share on other sites More sharing options...
lmcannon Posted March 2, 2014 Author Report Share Posted March 2, 2014 Wow! That's in bad shape. Front end looks out of wack also. Sent from my SM-N900T using Tapatalk What u mean the front outta wack? Quote Link to comment Share on other sites More sharing options...
imbill Posted March 2, 2014 Report Share Posted March 2, 2014 WELCOME !!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Denny2424 Posted March 2, 2014 Report Share Posted March 2, 2014 From the back the camber looks like it's out. Like the top of the tires are pointing in opposite directions. Sent from my SM-N900T using Tapatalk Quote Link to comment Share on other sites More sharing options...
03DMshee Posted March 2, 2014 Report Share Posted March 2, 2014 I hope you were being sarcastic when you asked that question...id buy a frame and start fron scratch...someone murdered the weld on back half....as far as the front...well thats self explanatory. .. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 2, 2014 Report Share Posted March 2, 2014 ok here is the actually parts that are left outta the moose racing kit What is the thick screw one idle screw? I bought the idle kit from motion pro does that replace that. Drain plug/screw on bottom of bowl Quote Link to comment Share on other sites More sharing options...
lmcannon Posted March 3, 2014 Author Report Share Posted March 3, 2014 Elevation is 193 weather is in it's 7-32f weather. No porting that I kno of. Toomey t-5 pipes. Stock air box wit open lid. Knn filter outerwares. I rebuilt carbs with moose racing kit. Kit came with 200 main. I couldn't get the other 2 jets out to replace. And didn't change needle. I did blow the cars out n jets out with carb cleaner. What should I base tune the carbs with? What jetting should I start with. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 3, 2014 Report Share Posted March 3, 2014 Couldn't remove pilots? Use a small flat head screwdriver. 27.5-30 pilots, around 300-320 maybe go fat due to cold 1 size every 20 deg drop for mains. If it has stock mains still running it like this will cause damage. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted March 3, 2014 Report Share Posted March 3, 2014 My rear subframe needs to be replaced or straighted. sweet repair, was the guy you bought this bike off drooling on himself? Quote Link to comment Share on other sites More sharing options...
lmcannon Posted March 4, 2014 Author Report Share Posted March 4, 2014 Lol no I think that's how he got it Quote Link to comment Share on other sites More sharing options...
