Located in Wisconsin Rapids, WISCONSIN
Asking: $8500
I've invested about $11,500 in this already without counting any time building the hybrid.  My brother and I built this ourselves and we took our time to do it correctly (motor is perfectly lined up with swingarm).  We put a lot of time into our hybrid projects.
I'm selling because I will have no more time to ride as I need to finish my dissertation and will be going on the job market next year (aka no more racing/riding for me for a while).  I've sold most all of my toys, and all I have left is my rubber ice racing quad and this.
The motor sits as low in the frame as possible (the correct way to build a hybrid).
Inframe pipes ARE possible as I cut the frame down-tubes out, but not all of them will fit, there are no restrictions where I race so I ran the OOF's.
4mil Hot Rods Crank (trued/welded)
72mm Wiesco Pistons
Billet Twister Cylinders ported by Kevin at HJR (aggressive dune port)
25cc domes (170lbs compression)
Adjustable timing plate
Lightened flywheel
Hinson Billet basket
Direct drive lockup and cover
billet water pump cover
billet stator cover
straight cut gears
VForce3's
Pingle Dual feed petcock
Billet Intakes 33-35mm
Keihin 35mm PWK Airstrikers (some pics show Keihin PJ 34mm carbs, I used both)
Pod filters
CPI BB OOF Pipes
CV4 Radiator hose with temp gauge
OEM wiring harness/cdi/coil/stator "drag cut"...only essential wires to run + kill switch.
Chassis:
YFZ frame/subframe
JB long travel a-arms (+2")
PEP 8 click fully adjustable front shocks
PEP big bottle fully adjustable rear shock
Stock swingarm
(Brand new billet lonestar carrier as spare)
Lonestar +2/+2 adjustable axle
Lonestar rear hubs (HONDA Pattern)
RPM Front hubs (HONDA Pattern)
Pro Peg nerf bars (with 1" lower peg mount for more leg room)
ASR-FX stem and clamp +2"
Tag CR-Dbl Hi Bars
Tag front bumper
Dual braided brake lines front, braided line rear
ASV clutch and brake lever
TRX450r thumb throttle
Quadtech seat with hump (2 holes in cover, have stock seat also)
Full Laker Custom set of plastic
Rath Swaybar
PEP's are LT freshly serviced by Seth at SF Racing.
Douglas or ITP front/rear rims with full set of American Racers (6-10 laps on most tires, I've got about 70 you can choose from, haha).
I'm sure I'm forgetting a few odds and ends.  For spare stuff, I have brand new moose stator and timing plate and good flywheel.  Spare Hot Rods 4mil crank in great shape that measures within spec (went with brand new because Jeff at Fast was having a sale and I wanted to start with new).  Spare motor mounts and bolts, brand new spare lonestar bearing carrier, spare frame (not cut for motor yet), full complete spare tranny, 1 tranny about half complete, HiPer Beadlock rear rims with holeshot tires as spares, and other small things.
Always ran VP113 with 32:1 mix. Honda transmission oil for clutch oil (same thing we run in our trx450r pro motors).
The clear plastic and white plastic piece in the next photo are just to deflect the snow-dust at the ice races...otherwise the filters get caked in snow since there is no air-box.
This thing is setup to handle like a dream on the ice.  It is the only quad that can easily beat our yfz/trx hybrid on the ice (that has won over 100 races the past 3 years at 6 different ice racing associations).
859342_10101949498860537_1123178962_o_zp
I will consider selling just the rolling chassis/motor separate but have not figured on a price.  I would prefer to sell the thing complete.  I DO NOT want to be left with just the motor as I have nothing to put it in.  I can always hold onto the chassis and rob parts from it if I sold the motor though.a
Serious inquiries only, please e-mail me at bjhoffman@wisc.edu or send me pm's on here or reply to this posting....whatever is easier and I'll get you my phone number so I can answer any questions you have.
haha yeah it gets cold out there!  I'm used to just reaching back and warming it up with the exhaust.
Buy this, and go race 1-2 SWIRA big race in Wisconsin, 2 Escanaba MI big race, and you'll win over $1500 easily.  Do that for a few years and it will pay for itself!
Race summer oval at dirt car tracks and make a couple hundred each time too.
Thought I'd have people jumping all over a clean, well built, full long travel PEP hybrid!  I started the price high...asking $7500.
$5k no motor pieces (all spare chassis parts and full long travel pep setup front and back or full flat-track setup).
  • 7 months later...
  • 4 years later...
