thomas h. Posted February 8, 2014 Report Share Posted February 8, 2014 The top is breaking up and the bottom sounds flat. Oem stator and coil Pickup gap 18 Carbs pwk 28 150 main 45 p No port stock cylinders, 21 domes fresh gas mix Pod filters Passed leak down. Good comp. I'll post up until successful. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted February 9, 2014 Author Report Share Posted February 9, 2014 Any thoughts ? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 9, 2014 Report Share Posted February 9, 2014 I have found with those carbs needles makee a huge diffrence it it has the silver needle with no markings ditch it and get n68a for stockish motors jjh for modified , if it sounds like its going on a 2 step or ignition break up on top swap coil and sometimes they test good but still are not. Flat bottom can be needle selection jets dont sound that far off with proper needle Quote Link to comment Share on other sites More sharing options...
thomas h. Posted February 9, 2014 Author Report Share Posted February 9, 2014 Thanks S06 I have zero exp with pwk. In has a brass needle now and I have a kit of jets / needles. Quote Link to comment Share on other sites More sharing options...
