10milmike Posted February 6, 2014 Report Share Posted February 6, 2014 If you have a lock up you will be fine with stock springs. Just add about about 15 grams to each arm. Hd springs are used when you do no have a lock up. Quote Link to comment Share on other sites More sharing options...
camatv Posted February 6, 2014 Report Share Posted February 6, 2014 the oem cable is the best one. and get a cable lubber already! with a cr or ez adjust lever, oem or motion pro cable with LUBE even a 15% over all 6 springs should be easy to pull. if thats to hard still you probably need to work on your upper body strength. if you cannot even pull in the lever how can you even hold on if you bunp a rock or stick, 1 Quote Link to comment Share on other sites More sharing options...
bansheefromhell Posted February 6, 2014 Author Report Share Posted February 6, 2014 Trust me it will never see rocks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
