Where to start...
ringneckryan
Long story short I bought this engine that's way outta my league and now I gotta jet it. I have burnt down sled engines before not jetting them correctly and do NOT want a repeat of that.
I ride between 2500 and 3000 ft. 65.5mm bore. Stock stroke. 17cc domes. Numera cast pistons hi comp. Aggressive trail port. I think the reeds are stock. FMF SST pipes and I run 100LL av gas. I am wanting to run my stock Keihin carbs.
Are you wanting to run stock carbs or kehins? On stock carbs (Mikuni 26mm) I'd say start 350 mains 30 pilots and fine tune from there doing a couple plug chops/reads until it's perfect.... Rule of thumb start fat and lean out from there if needed.... On stock carbs you'll probably end up at a 330 main and 27.5 pilot..
