bad o ring ?
bansman76
hey guys..  ive noticed on my new motor that when I start it and let it run for a few, it smokes more out of the right side and has a bit of fluid coming out of exhaust  (im thinking its coolant ) .. so  I took carbs,pipes off and preformed a leakdown test.. it held 6 psi til I loosened up the radiator cap, then started bubbling in radiator and loosing pressure.
   my question is would this mean a pinched or bad or ring in the noss head  ??
  • Replies 44
  • Created
  • Last Reply
Top Posters In This Topic
well I tore it down and replaced all o rings n the head with a set I had on shelf.   I didn't attach all hoses or fill radiator up ,  done the leakdown test and it leaked at the head again..  I torqued the head down in 4 stages .  1 at 10lbs   2 at 15lbs   3 at 20lbs   4 at 22lbs ...  im in need of opinions or ideas ?    please and ty
New seals should be in tomorrow. Should I try them one more time ? I know that the first time I pulled the head off I looked at spark plugs and the right plug has some white spots. The left side was completely chocolate colored no white at all. I wish I hadve sent the whole motor out to be built instead of me assembling it.
Sand your cylinders and head on the granite slab. Assemble with new O rings. You put the small O rings on top of the domes, right? Just snug the cylinder base nuts. Torque the head nuts. Then tighten the base nuts. Then leakdown test it. There is also a slight possibility that it's the rubber plugs in the bottom of the cylinders. Just to cover that, you could coat the plugs with 1211, and reinstall them.
