wayne_smith97 Posted February 2, 2014 Author Report Share Posted February 2, 2014 Went out to the shop. Kicked it about five times and it fired right up. Ran for about three minutes like a dream. Then it dies. Kicked it until leg is sore and nothing then Kick it again about five minutes later and fires right back up. Runs for a few minutes then dies. This time can't get it to fire back up. Any thoughts Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 2, 2014 Report Share Posted February 2, 2014 fuel cap vent working? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 2, 2014 Author Report Share Posted February 2, 2014 fuel cap vent working? I don't know I will take the cap off when I try again. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 2, 2014 Author Report Share Posted February 2, 2014 fuel cap vent working? I took the cap off and kicked another few minutes and nothing Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 2, 2014 Author Report Share Posted February 2, 2014 ^^^This. Flywheel spun. I took the flywheel off and key is good. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 2, 2014 Author Report Share Posted February 2, 2014 Went out and tried again and put new plugs in and kicked fifty times and if fired up. Ran for a minute or two rapped out real nice and clean. Then it bogged out and died again. I'm trying to get it to run so I can sync the carbs(sync tool). They sound fine now just want to tune it in. I'm ready to give up Edit: also double checked pickup gap and checked for fuel in the bowls as soon as it bogged out Quote Link to comment Share on other sites More sharing options...
oldskool Posted February 2, 2014 Report Share Posted February 2, 2014 Its something simple. When it does not fire, check for spark. If you got no spark, check all grounds. Pull boots off plug wires and cut a 1/4 inch off of wire and put boot back on. If you got spark and it wont fire, try removing pods, open throttle wide open, then with some type squirt bottle, shoot a nice dose of gas through carbs. release throttle, turn kill switch to run and try it Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Its something simple. When it does not fire, check for spark. If you got no spark, check all grounds. Pull boots off plug wires and cut a 1/4 inch off of wire and put boot back on. If you got spark and it wont fire, try removing pods, open throttle wide open, then with some type squirt bottle, shoot a nice dose of gas through carbs. release throttle, turn kill switch to run and try it When it bogs out I pulled the plugs and checked for fire. It's still firing. I agree it's something simple. I will try the squirt bottle when it bogs out again. I was wondering if those carb rebuild kits are crappy and are causing me problems Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 3, 2014 Report Share Posted February 3, 2014 Do have fuel flowing good and strong out of the petcock? Plugged sceen? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Do have fuel flowing good and strong out of the petcock? Plugged sceen? It seems to be but I will check again Quote Link to comment Share on other sites More sharing options...
oldskool Posted February 3, 2014 Report Share Posted February 3, 2014 where's your air screw sitting at?. A bog can be too much fuel or too much air Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 3, 2014 Author Report Share Posted February 3, 2014 where's your air screw sitting at?. A bog can be too much fuel or too much air 1 3/4 turns out right now. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted February 3, 2014 Report Share Posted February 3, 2014 Freshy fresh fuel? Premium fuel is going bad REALLY FAST lately. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Freshy fresh fuel? Premium fuel is going bad REALLY FAST lately. Not really. It's about 3 weeks old Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted February 3, 2014 Report Share Posted February 3, 2014 You can't tell how long it was in the ground. (Premium is selling less often in this down economy, so it sits longer) We had a guy who bought gas and rode....then the following weekend it needed a pull start to fire. Try fresh gas. Quote Link to comment Share on other sites More sharing options...
