rmrider12522 Posted January 24, 2014 Report Share Posted January 24, 2014 Everything is new, stator, coil, cdi. flyhwheel but no spark. I was riding one day in the winter and it just died, wasnt beating on it or anything. Just cruising and it died, any help would be appreciated, thank you. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted January 24, 2014 Report Share Posted January 24, 2014 Tors unplugged? Check on off switch/ key switch. If keyswitch is deleted make sure its spliced correctly Harness plugs/connectors Make sure pickup hasn't come loose Were all the replacements done after issue happened? Sent from my Galaxy Nexus Quote Link to comment Share on other sites More sharing options...
Starwriter Posted January 24, 2014 Report Share Posted January 24, 2014 Let me guess, Ricky Stator or RM stator? Aftermarket stators and flywheels are junk. Quote Link to comment Share on other sites More sharing options...
rmrider12522 Posted January 24, 2014 Author Report Share Posted January 24, 2014 Which wires are supposed to be spliced for the key switch? because i got it with it deleted, and it was sort of rigged. Tors was unplugged but i rewired it all so it worked properly Quote Link to comment Share on other sites More sharing options...
rmrider12522 Posted January 24, 2014 Author Report Share Posted January 24, 2014 Nah newest stator was from the local dealer Quote Link to comment Share on other sites More sharing options...
Starwriter Posted January 24, 2014 Report Share Posted January 24, 2014 Red/black and black key switch wires need to be connected together for it to run. Make sure the flywheel didn't fall off. Check the pickup coil gap. Check to see if the wire harness melted to the right stinger and shorted out. If all that checks out, you're going to have to break out the multimeter and start doing resistance checks. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted January 24, 2014 Report Share Posted January 24, 2014 Which wires are supposed to be spliced for the key switch? because i got it with it deleted, and it was sort of rigged. Tors was unplugged but i rewired it all so it worked properly plug that has a black and red wire edit guess i was too slow! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted January 25, 2014 Report Share Posted January 25, 2014 I've even had the contacts in the thumb on/off switch get dirty and just shut it off all on it's own. Quote Link to comment Share on other sites More sharing options...
rmrider12522 Posted January 25, 2014 Author Report Share Posted January 25, 2014 All very possible cause it is getting pretty old. Ill check it out tomorrow, thanks everyone! Quote Link to comment Share on other sites More sharing options...
