jetting
littleman83
"English Mutha Fucka, Do You Speak It?" Jules Winnfield - Pulp Fiction
Use proper spelling and punctuation if you want help.
You understand the shit that's spewing from your brain thru your finger tips.
We're here to help you try and fix your bike, not proof read some 8th graders text to his posse, crew, clique or what ever the fuck its called now a days.
Show us a little respect and you'll get yours.
And BTW, I could that have it running tip top in < 10 mins.
  • Like 1
Perhaps he has trouble speaking english...if you were at sea level and running pump fuel, stock carbs and stock port work, I would recommend you bump pilot jets to 27.5, needle on middle clip, and start your mains a little fat around 270. Turn your air screws about 1.5 full rotations out, then sync your carbs and adjust from there. Probably will end up between 250 and 260. Hope this helps.
