Atomic Monkey Posted February 13, 2014 Author Report Share Posted February 13, 2014 Not crazy about that knife edge either. Still doing a lot of learning fo sure! 1 Quote Link to comment Share on other sites More sharing options...
registered user Posted February 13, 2014 Report Share Posted February 13, 2014 its all good man. looked back on alot of shit i did and wondered why the hell i did it. im sure people tend to replicate what they see from pictures. pretty sure near every pic around here is knifed and Veed on the bridge so its understandable you would do it similar. try to think outside the box for a better way. maybe look at how other cylinders are and gather some ideas. get a peek at calvins jugs for some ideas. on the stuff i do theres not one sharp edge except where the window joines the bore. but everyone has there own method. keep at it and youll get it sorted out Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted February 13, 2014 Author Report Share Posted February 13, 2014 There hasn't been anything else done to the cylinders since the pics I posted. There should be enough left on the bridge to rework it. With everything that I've been learning, there might be some welding going on. Mostly I'm worried about poking through the outer walls. I was working on a snowmobile tonight, a 600 twin Rotax. The intake layout... no windows in the piston, and the intake area is completely open into the transfers... just adds to the thought process. Quote Link to comment Share on other sites More sharing options...
Pasi S. Posted February 13, 2014 Report Share Posted February 13, 2014 You are doing good. My amateur advice is, that you can always take them off and port more. I´m in round 3 with my cylinders. If I can remember right, the stock bridge is 11mm wide. In my cylinders it´s now 6mm and knife edge. For my friend I left it at 9mm and more rounded. Quote Link to comment Share on other sites More sharing options...
registered user Posted February 14, 2014 Report Share Posted February 14, 2014 i never tried this but i wonder if the bridge is thick enough to accomplish such a shape Quote Link to comment Share on other sites More sharing options...
Colby Posted February 14, 2014 Report Share Posted February 14, 2014 It is thick enough for that shape. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted February 14, 2014 Report Share Posted February 14, 2014 You are doing good. My amateur advice is, that you can always take them off and port more. I´m in round 3 with my cylinders. If I can remember right, the stock bridge is 11mm wide. In my cylinders it´s now 6mm and knife edge. For my friend I left it at 9mm and more rounded. this is how i did mine. Make a change and note the effect. Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted February 14, 2014 Author Report Share Posted February 14, 2014 There's enough there to get it rounded. The bridge is still the stock width, so putting a radius on the cylinder side edges, and still have enough support for the rings shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted March 11, 2014 Author Report Share Posted March 11, 2014 Still getting it done. Welding the cylinders soon. Quote Link to comment Share on other sites More sharing options...
registered user Posted March 12, 2014 Report Share Posted March 12, 2014 what do you weld ? Quote Link to comment Share on other sites More sharing options...
uman1030 Posted March 12, 2014 Report Share Posted March 12, 2014 what do you weld ? clearly the reply of a parts changer. 2 Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted March 12, 2014 Report Share Posted March 12, 2014 clearly the reply of a parts changer.Haha Sent from a van down by the river Quote Link to comment Share on other sites More sharing options...
registered user Posted March 13, 2014 Report Share Posted March 13, 2014 clearly the reply of a parts changer. suprised you didnt tell him to send it somewhere. hahahh. i know your type, replace spark plugs and turn airscrews are your limitations im not familiar with banshees or where they need welded. ive welded some other cylinders but explaining where and why would be above your head so i wont bother with the details Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted March 13, 2014 Report Share Posted March 13, 2014 im not familiar with banshees or where they need welded. ive welded some other cylinders but explaining where and why would be above your head so i wont bother with the detailsPictures are worth a 1000 words..... ....yep , still waiting on pictures of any of your so called engine work. Sent from a van down by the river Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted April 10, 2014 Author Report Share Posted April 10, 2014 Just got the cylinders back from the welder. Basically just had some voids filled so I could work the transfers and not have to worry about popping through the casting. Quote Link to comment Share on other sites More sharing options...
