Compression questions
BAMF87
As you your altitude increases the air thins giving you a lower cranking compression. this doesnt change compression ratio but just effective compression. at 2500 ft asl your cranking compression reading will be about 93% of what you would be at sea level. also other factors that come in to play like air temperature as well
depending on port timing also it can show lower numbers during cranking compression test cause ports overlap letting some compression leak out. also air temp changes density so 93% would be at 59F wich is what most altitude compensation charts use.
general rule of thumb is about 4% per 1000 ft
I got a little more at sea level with my HJR port. I though I wanted more too but the crap 91 we get here makes me Change my mind.
whats your cranking compression at sea level? and is it a dune port also?
D port 4 mill 127
then with a 93% altitude compensation compression adjustment that puts him not far off then with in a couple psi. according to the chart he would be at about 128 at sea level.
close to the same assuming you both have similar combustion chamber volume.
Compression Test Altitude Compensation Factors
Altitude Factor
500 0.987
1500 0.960
2500 0.933
3500 0.907
4500 0.880
5500 0.853
6500 0.826
7500 0.800
8500 0.773
