Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 I have cut the wire back ½". How do you replace the wire? It's attached to the coil. Both caps metered at around 5k ohm Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted January 12, 2014 Report Share Posted January 12, 2014 (edited) If they metered good then that's probably not it. If the ground is good and stator is good and pick up gap is ok. Then make sure flywheel isn't shot. Pull the flywheel and make sure key isn't sheared. That will make random spark and then shake the flywheel and see how bad it rattles Edited January 12, 2014 by wayne_smith97 1 Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 I've had the key out to swap the stator. It looked fine. I had to take the stator from my old motor and mount it in the new motor because of the wiring harness. I left the flywheel tho. Would it be a cdi going bad or a bad coil? They don't usually work half ass tho... Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted January 12, 2014 Report Share Posted January 12, 2014 From my experience Cdi and stator are all or nothing. Not saying it couldn't happen. Quote Link to comment Share on other sites More sharing options...
troyzstang Posted January 12, 2014 Report Share Posted January 12, 2014 Just spent a few hours tinkering on two bikes with spark issues too. First bike turned out to be the stator wires were installed from the factory in the wrong location. Second bike had a bad CDI. I hate electrical issues. If you now have spark, check the fuel system. Have you checked the carb slides to ensure they closing or bottoming out in the carbs? Good luck Troy Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 From my experience Cdi and stator are all or nothing. Not saying it couldn't happen. Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 From my experience Cdi and stator are all or nothing. Not saying it couldn't happen. So you think it may be just a bad ground? It sucks cause I don't have any spare electrical parts to swap in. I do have the stator that came with the motor but it has a different connector end. I would have to hard wire. Both stators have the same resistance. I think Maybe I'll swap out the flywheel today from my 87 motor since I'm using the stator from my 87 motor. What do you think it may be? Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Just spent a few hours tinkering on two bikes with spark issues too. First bike turned out to be the stator wires were installed from the factory in the wrong location. Second bike had a bad CDI. I hate electrical issues. If you now have spark, check the fuel system. Have you checked the carb slides to ensure they closing or bottoming out in the carbs? Good luck Troy The stator i installed worked on my 87 motor. Spark is only sometime. Like every other kick but sometimes on every kick. Carb slides are bottoming out. Reeds are good. I cleaned the pilot jets. I even tried spraying carb cleaner on my filters to get it to start. Nothing yet. Have you ever heard of anyone running a separate ground wire from the motor to the chassis? Where would be a good place to do it? Thanks Quote Link to comment Share on other sites More sharing options...
oldskool Posted January 12, 2014 Report Share Posted January 12, 2014 You seem to be getting spark, are you sure you have no leaks at intake. Is choke tube installed and in good condition. Try removing filters, lift slides and squirt some gas through carbs, then try to start. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted January 12, 2014 Report Share Posted January 12, 2014 Don't use carb cleaner or starting fluid please! It will ruin your motor Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 From my experience Cdi and stator are all or nothing. Not saying it couldn't happen. I have spark only every 4-5 kicks. Stator windings test as should and I've tried two different flywheels. It has to be my cdi box? Producing only spark sometimes? Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 12, 2014 Author Report Share Posted January 12, 2014 You seem to be getting spark, are you sure you have no leaks at intake. Is choke tube installed and in good condition. Try removing filters, lift slides and squirt some gas through carbs, then try to start.I only get spark every 4-5 kicks? Tested the stator winding and coil. Both get the desired resistances. Must be my cdi box? Only spark sometimes? Quote Link to comment Share on other sites More sharing options...
Newcs222 Posted January 13, 2014 Author Report Share Posted January 13, 2014 You seem to be getting spark, are you sure you have no leaks at intake. Is choke tube installed and in good condition. Try removing filters, lift slides and squirt some gas through carbs, then try to start. I installed the carb sliders backwards. I was getting way too much fuel. Still wasnt starting. Swapped out the stator, fired up! Runs good. Even tho I had the right reading off the windings the stator was still bad. Quote Link to comment Share on other sites More sharing options...
oldskool Posted January 14, 2014 Report Share Posted January 14, 2014 Good news Quote Link to comment Share on other sites More sharing options...
