oldskool Posted January 11, 2014 Report Share Posted January 11, 2014 you don't know if the cylinders are ported for the extra stroke. That's why the guys are telling you to send it to a builder. You can port cylinders for stock stroke, spacer plate, 4mill no plate, 5mil etc. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 11, 2014 Report Share Posted January 11, 2014 Ok, I am being nice when I say my next statement. Much of what you are saying is a hot mess. Especially the stock cyl/Athena cyl comparison. That's like saying cubs are like stock cyls, except have triple exhaust, aux. ports, nikasil and they are cast together as one jug. Other then that they are the same. ( bustin your balls by the way) But on to the set up. You are sure it's 5mm crank stroke not 5mm longer rod? It could be both but much of your info is conflicting. Also, the only way to know if you can run them with out a plate is to have a builder determine if it messes up the port geometry. As taking that spacer out lowers the cylinder. This usually requires additional port work as well as having the head/domes set up to match. With what your saying it seems that in your case you need a builder to take a look to advise you where to go with it. Not the local Yutz mechanic! No matter how many banshees they may do top ends on. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted January 11, 2014 Report Share Posted January 11, 2014 <p>Smacks of someone trying to be cheap.</p> Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 11, 2014 Report Share Posted January 11, 2014 Ive been reading this since day one and have been wondering does he mean stock stroke 5mil long rod? or 5mil stroke who knows what rod? we may never know. buy a degree wheel,some solder and read up you got lots to learn Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 11, 2014 Report Share Posted January 11, 2014 Also, if you are dead set on letting your local mechanic do this for you, that means you trust him. Since he's such an expert on banshees why can't he answer your question? There is a huge difference between the guy that can bore your jugs and assemble the top end, and the guy that has a machine shop as well as oodles of mock up cases, gaskets, plates, and a degree wheel to inspect your current mess and sort it out properly be it with port work and new domes on correct height gaskets, or figuring out how to get it to run right with out changing it. If your Mechanic can't set up your domes or tell you whether or not to run that plate you are in the wrong spot. I ran my banshee for years with the local shop behind me and i thought it was boss as fuck. Then I finally sent it to a proven builder off HQ and holy Fuck! There is a huge difference. Just letting ya know. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 11, 2014 Report Share Posted January 11, 2014 Ive been reading this since day one and have been wondering does he mean stock stroke 5mil long rod? or 5mil stroke who knows what rod? we may never know. buy a degree wheel,some solder and read up you got lots to learnI think the only 5mm stroker crank I saw was a twister. I think we both know there probably isn't a twister in that motor with out someone knowing. Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 11, 2014 Report Share Posted January 11, 2014 Twister was the only name that come to my mind as well. when odd strokes are brought up they are usually his cranks. not saying its not a stock stroked crank, its just not that popular any more. and who the fuck would spend good money on a twister crank then cheap out on the cylinders. 1 Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted January 12, 2014 Report Share Posted January 12, 2014 It is probably a stock stroke long rod crank... No way there is a Twister crank in that motor.... I was thinking the same thing, that no one makes a 5mil stroker crank except for a custom build... And, it most likely does not have a high dollar crank, with cheapo cyls like Athena... Whoever he bought it from lied there ass off, to sell that bike..... It NEEDS to be sent to someone who knows how to build custom Banshee engines, not the local powersport guy.... The site sponsors deal with more Banshee engines in a week than the local guy will do in 5 years.... Quote Link to comment Share on other sites More sharing options...
87sheestillkickin Posted January 12, 2014 Report Share Posted January 12, 2014 Ive heard people call 4mm long rod 5mm cranks before Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 12, 2014 Report Share Posted January 12, 2014 Ive heard people call 4mm long rod 5mm cranks beforewell they were wrong. call it what it is and you wont sound like a dumbshit like they do. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted January 12, 2014 Report Share Posted January 12, 2014 Ive heard people call 4mm long rod 5mm cranks beforeTrinity use to tell people that longer rods = more cc's from the extra stroke. FFS Quote Link to comment Share on other sites More sharing options...
87sheestillkickin Posted January 12, 2014 Report Share Posted January 12, 2014 Yea i dont call them 5mm bc thats not what they are. Im jus saying ive seen it on craigslist and heard people call it that Quote Link to comment Share on other sites More sharing options...
