WINDYCITYJOHN400 Posted January 12, 2014 Report Share Posted January 12, 2014 6 pack rack. 2 gallon tank in it. No offense but those headlights are very obnoxious, why such big headlights? Try riding WOT in dunes at night. You'll figure out real fast where the phrase "Form follows function" comes from. His bike has the full baja look. That bike is a beast and set up well. Killer shocks to go with killer lighting. Looks good to me. Quote Link to comment Share on other sites More sharing options...
d00med Posted January 12, 2014 Report Share Posted January 12, 2014 Glamis night ridding is a must to have Very good lighting. Mine Sent from my iPhone using Tapatalk Nice Quote Link to comment Share on other sites More sharing options...
Azryll Posted January 12, 2014 Report Share Posted January 12, 2014 Here's the post of BigRed's spare tank http://bansheehq.com/forums/index.php?showtopic=145881&page=2 Quote Link to comment Share on other sites More sharing options...
rubberneck Posted January 12, 2014 Report Share Posted January 12, 2014 Even with killer lights the dunes can be very hard to ride at night. Its almost dissorienting (sp?) if that makes sense. So the bigger the better. Even with LEDs, the bigger the reflector the more light they will put where you need it. The trend is smaller and smaller lights but that isnt necessarily the best way to go for function. What i have found to work the best for me is a light or 2 with a wide pattern and a lot of spill so that you can read the contours better and 1 light with a little more of a combo patter for distance. I find dessert type terrain and woods much easier than dunes at night because there are objects to give you a frame of reference. More on topic to the original post i used to run a 6 pack rack on my shee with a 1.25 or 1.5 gallon can i found at ACe hardware that fit perfect. Only problem was with my shearers, the stingers aimed right at the bottom front corner of the can and started to melt the can a bit after a couple long rides. I started to feel uncomfortable with having a bomb strapped down back there. I ended up getting a 4 stroke and its what i ride mostly now. If i were dead set on doing it again i would build some turn down end caps. just my .02 Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted January 15, 2014 Author Report Share Posted January 15, 2014 A little better view from the top. Sent from my iPad using Tapatalk Have a closeup? That looks like the easiest solution. Not as good as a larger tank but I think that would give me enough fuel for most rides. As for adding a 2 gallon tank to the back, I do worry about melting the tank with the exhaust. If that's a better route, which grab bar works best? I have the typical older style cooler tack, but I think I bent it a bit when I wreck some years ago. As for the lights, I really don't care if people think they are ugly, I can unbolt them in about 10 minute with 2 bolts if they are in the way. They are Euro Pattern beam you see on a lot of buggies. LED lightbars were not even made for my banshee back when I got these years ago. The problem is I keep melting my stators Quote Link to comment Share on other sites More sharing options...
banshee#44 Posted January 17, 2014 Report Share Posted January 17, 2014 I've been having the same issue with having fullbores we go on long rides and I usually have to worry about my gas which always sucks .I've contemplated cutting them to fit a desert tank but the thought of taking a blade to them and fucking up keeps me from doing it . Sent from my SPH-L720 using Tapatalk Quote Link to comment Share on other sites More sharing options...
banshee#44 Posted January 17, 2014 Report Share Posted January 17, 2014 I've also thought of making mounts where the air box use to be to put an aluminum gas tank there and run lines from the original tank to the smaller one and from that to the carbs . Sent from my SPH-L720 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted January 17, 2014 Report Share Posted January 17, 2014 (edited) Why not just bungee a couple one liter soda bottles full of fuel up in the bumper area? I hate long rides... Edited January 17, 2014 by Banshee Chad Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted January 19, 2014 Author Report Share Posted January 19, 2014 Why not just bungee a couple one liter soda bottles full of fuel up in the bumper area? I hate long rides... That actually sounds pretty dangerous Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted January 20, 2014 Report Share Posted January 20, 2014 That actually sounds pretty dangerous Why so? Not like it's taped to the exhaust Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted January 20, 2014 Author Report Share Posted January 20, 2014 Why so? Not like it's taped to the exhaust They could rub and leak, or crack, and they would be near the exhaust. Plus 2 liters of gas sin't going to get me very far unfortunately. Whats the best rack for holding a gas can? Whats teh best gas can to put in the rack? Quote Link to comment Share on other sites More sharing options...
Banshee Chad Posted January 21, 2014 Report Share Posted January 21, 2014 If u don't do it often I think it's be fine. The link I posted will hold the most cans.. Think it'll hold 2 1 gallons and either a 2.5 or a cooler in the middle. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted January 21, 2014 Author Report Share Posted January 21, 2014 If u don't do it often I think it's be fine. The link I posted will hold the most cans.. Think it'll hold 2 1 gallons and either a 2.5 or a cooler in the middle. Well I do do it often, just about every time out... For now I'm just riding the 250r even though its way slower. Quote Link to comment Share on other sites More sharing options...
hp2000 Posted January 24, 2014 Report Share Posted January 24, 2014 Well I do do it often, just about every time out... For now I'm just riding the 250r even though its way slower. When you heading out to glamis again? What's a normal ride for you before you run out of fuel ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hp2000 Posted January 24, 2014 Report Share Posted January 24, 2014 Btw banshees are all over glamis and a good group of them rides with us. Also 3 of them are 421 cubs 1 is a 485 ESR another stock cyl 4mil and the rest 350 motors that have very aggressive port work. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
