ZILLAKILLA Posted January 8, 2014 Report Share Posted January 8, 2014 Upgrading on performance. I was told to put heavier springs on the clutch will help transfer the horsepower how do I get that done step-by-step? Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 8, 2014 Report Share Posted January 8, 2014 Remove old spring, install new hd version. not the best way though. look into lockup clutches Quote Link to comment Share on other sites More sharing options...
BUILDER Posted January 8, 2014 Report Share Posted January 8, 2014 Drain the water drain the oil pull the coolant hose off of the clutch cover remove the foot peg remove the rear brake peddle remove the clutch cover remove the clutch springs install new springs and repeat the process that you used to take it apart. Quote Link to comment Share on other sites More sharing options...
Finch Posted January 8, 2014 Report Share Posted January 8, 2014 <p>^ forgot kick starter</p> Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 8, 2014 Report Share Posted January 8, 2014 Fast and driveline have great clutches Might as well do a water pump while you're in there. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted January 8, 2014 Report Share Posted January 8, 2014 <p>^ forgot kick starter</p> Damn your right I did forget that Quote Link to comment Share on other sites More sharing options...
