Bennett131 Posted January 7, 2014 Report Share Posted January 7, 2014 ok so I drove home last night around 11 pm or so and I plugged my truck in because its -12 here in pa. the truck ran fine last night and I started it up for 10 or so minutes this morning and I put it in reverse to leave and everything felt normal...I pulled out of my driveway and it felt as if I were in neutral I had to rev it to 2000rpm and then it moved. once I got going it seemed fine but once it got up to normal temp if I got on it a little and hit 3000rpm it would die right out? what could be my problem? and yes I do put anti gel treatment in my fuel? any help is appreciated thanks ahead of time. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 7, 2014 Report Share Posted January 7, 2014 Sounds like a trans/torque converter issue. Weird no lights came on. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 well I haven't changed anything except my engine oil/filter and my air filter and my fuel filter since ive owned it....meaning I haven't replaced my tranny fluid. but just so we know what were talking about its an 08 duramax with 80k miles on it. and my check engine light was on but it came on two weeks ago because I put an exhaust on it and unplugged my dpf. been running fine except this morning ill check out the tranny I suppose are you guys positive my fuel isn't just gelling up tho? maybe I just didn't put in enough of the anti gel shit? Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 I just have trouble believing that my Allison tranny would be going out with so few miles on the truck it being stock other than my exhaust and I don't beat it. also im not sure how tranny fluid well enough to make it do that would disappear somehow in like 6 hours. not saying you guys are wrong just clarifying everything. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 im not sure what trans fluid is in there now but as far as everything else I own I only run quality fluids. Quote Link to comment Share on other sites More sharing options...
sidewayz Posted January 7, 2014 Report Share Posted January 7, 2014 When you say it just dies out..... what do you mean? Motor stalls? Tranny slips? Even with 80 k miles , any medium to heavy duty on the truck would need some sort of trans service. Fluid / filter change. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 its like its running out of fuel at 3 grand then it runs fine again and it takes off good until it gets there tranny doesent seem to slip and the only thing I haul is myself and my banshee. Quote Link to comment Share on other sites More sharing options...
sidewayz Posted January 7, 2014 Report Share Posted January 7, 2014 It may be gelling , we have half our fleet dead in the yard due to fuel issues. Its cold. 1 Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted January 7, 2014 Report Share Posted January 7, 2014 Have you ever check the trans fluid? It could just be low or just need to be serviced. Just my.02 Quote Link to comment Share on other sites More sharing options...
m671054 Posted January 7, 2014 Report Share Posted January 7, 2014 You have something to fool the ecm about the modded exh? could be part or the problem. look for transynd for your atf. should just be due for service now. First part couldve been caused by convertor drainback,search for a tsb on that. second part could be fuel retriction. good luck. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 it was serviced when I bought it 15k miles ago I checked my trans fluid about a month ago it was good then and I maybe put 400 miles on since I checked it ill just have to check everything out here after work I suppose thanks for all the help guys Quote Link to comment Share on other sites More sharing options...
Finch Posted January 7, 2014 Report Share Posted January 7, 2014 <p>Should of bought a Ford lol but on a serious note just cuz its a allison doesn't mean its bulletproof ya there one of the best trans but just like anything can still have probs I've seen a few go out at 60k.</p> 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 7, 2014 Report Share Posted January 7, 2014 It's fuel related. I had a 2001 Cummins that did the same exact shit. It only did it when it was cold. I just about guarantee you've got fuel gelling. Quote Link to comment Share on other sites More sharing options...
uman1030 Posted January 7, 2014 Report Share Posted January 7, 2014 We had 10 out of 14 machines that wouldn't start last night and the 4 that did, didnt run right due to gelling diesel -45 with wind chill is hell on them when no preemptive measures have Been taken. 1 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted January 7, 2014 Author Report Share Posted January 7, 2014 it was fuel related and I did have a ford with 55k miles on it I think it lasted me 6 days and took a huge shit anyways... I brought it inside for a few hours problem solved. Quote Link to comment Share on other sites More sharing options...
