hoppedupandcutdown Posted January 3, 2014 Report Share Posted January 3, 2014 Everything you need to know and more... http://bansheehq.com/forums/index.php?showtopic=133650 Do you have/had a key switch? Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 3, 2014 Author Report Share Posted January 3, 2014 Yes there is still a key switch, should I jump the wires and try spark with the switch eliminated? Quote Link to comment Share on other sites More sharing options...
uman1030 Posted January 3, 2014 Report Share Posted January 3, 2014 Yes there is still a key switch, should I jump the wires and try spark with the switch eliminated? surely cant hurt and will help eliminate possible causes. i know you said tors was eliminated and you went thru to clean up some wires. did you make sure to leave the Tors brain unplugged if it was still on the bike? Quote Link to comment Share on other sites More sharing options...
baker Posted January 3, 2014 Report Share Posted January 3, 2014 Stator took a shit maybe? Ive had them just die out while riding. Get that ohm reader out get a clymers check it out, dont buy a ricky stator ebay junk. I did and it lasted a week just died out while riding wheelies. Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 3, 2014 Author Report Share Posted January 3, 2014 surely cant hurt and will help eliminate possible causes. i know you said tors was eliminated and you went thru to clean up some wires. did you make sure to leave the Tors brain unplugged if it was still on the bike? The tors and all components was previously removed. I will remove the ignition this afternoon and post results of the ohms testing also Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 3, 2014 Author Report Share Posted January 3, 2014 Yeah I'm thinking the stator possibly. Um thing to get to testing this afternoon when I get off work. Damn day job always gettin in the way Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 5, 2014 Author Report Share Posted January 5, 2014 After checking all the wiring and testing the stator ( tested good ) I bypassed the ignition and determined that was the problem. Atleast it was something easy to fix. Thanks guys Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted January 5, 2014 Report Share Posted January 5, 2014 I bypassed the ignition and determined that was the problem. please clarify... Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 6, 2014 Author Report Share Posted January 6, 2014 please clarify... Either the ignition or the wiring to the ignition was malfunctioning, I cut and tied the wires directly, one kick and the banshee fired right up Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted January 6, 2014 Report Share Posted January 6, 2014 ignition...the CDI? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted January 6, 2014 Report Share Posted January 6, 2014 The key switch. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted January 6, 2014 Report Share Posted January 6, 2014 The key switch. Yeah, I know, I was trying to get him to say it...lol I deal with that on cars with people all the time, the ignition switch or the key and cylinder...2 different things. The key on a Banshee, definatly is not the ignition. Quote Link to comment Share on other sites More sharing options...
bacons-banshee Posted January 7, 2014 Author Report Share Posted January 7, 2014 Yeah, My apologies. I did bypass the KEY SWITCH lol and now everything is good.. and after I got the 2003 running right I started messing with the 1994. it has vforce 2 reeds and the inner reeds were cracked, very simple fix. Thank you all again, this is my first successful forum I have posted on. Quote Link to comment Share on other sites More sharing options...
