new Banshee owner
the g1
Another question. Pistons look almost new and jugs look good, so should I hone and install new rings or just slip the jugs back on with the old rings. Am I going to loose some comprehension reinstalling the old rings? Trying to put together an order assuming  my crank bearings are good and  before my puller shows up.
  • 3 weeks later...
After new crank bearings, new seals, and a #2 transmission bearing the banshee passed the leak down test this morning. How do you guys hold the flywheel to torque it?
If your using a traditional torque wrench there is a thread in the technical section that's shows how to make a tool to hold it still. Or you could use a strap wrench but I would go with that tool
