2005shee Posted December 31, 2013 Report Share Posted December 31, 2013 ive only had my banshee about a month, its my first two stroke of my own, not ridden many others. ive noticed that when I first start it up and let it idle to warm up the left exhaust doesn't produce as much air and the header stays cold much longer than the left as in touching the left header after about a minute its still ice cold but the right one is fairly warm. also if I revv it just a little bit the left cylinder will backfire every time. after its warm though its fine and both cylinders produce the same amount of exhaust or at least close enough where I cant tell. both carbs have same jets and are synced and cleaned. the compression is within 2 lbs of each other (116 and 118) with the left just slightly lower but that wouldn't be it I don't think, any ideas? also the only known mods are Toomey t5s and open airbox. Quote Link to comment Share on other sites More sharing options...
2005shee Posted December 31, 2013 Author Report Share Posted December 31, 2013 also both spark plugs are new. and when looking at them they are like the color of chocolate milk, pretty sure that means theyre running ok. and gas is mixed 32:1 with castor 927 and 93 octane. Quote Link to comment Share on other sites More sharing options...
Sandking Posted December 31, 2013 Report Share Posted December 31, 2013 Switch plug caps. It may be time for new ones Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Zillaguy Posted December 31, 2013 Report Share Posted December 31, 2013 ^^^^ What he said^^^^^ best bet is to just change them out, they are cheap.... Quote Link to comment Share on other sites More sharing options...
2005shee Posted December 31, 2013 Author Report Share Posted December 31, 2013 ill have to try that. and you guys think that could cause it to only do it whil its cold? it runs fine after warmed up and it never bogs down or backfires at ful throttle after its warm of course. Quote Link to comment Share on other sites More sharing options...
2005shee Posted December 31, 2013 Author Report Share Posted December 31, 2013 also will any caps work or at least that fit or are they banshee specific? Quote Link to comment Share on other sites More sharing options...
