As far as I can tell nothing's been done to the motor.  Still has stock head and carbs with TORS.  Only noticeable mods when I bought it 3 years ago were Toomey T5's, a Moose boost bottle, and K&N drop in filter.  Has a gripper seat cover also.
Things I've added:  TM Designworks Case saver, new O-ring chain and front sprocket.  New shifter seal, countershaft seal, and billet neutral switch blockoff.  Chariot performance oversized aluminum waterpump impeller and black aluminum cover.  Mull engineering billet waterpump drive gear.  New oversized polished aluminum radiator and new hoses.  Full Flight +2/+1 A-arms. It had some ugly graphics kit on it, so I stripped that off and put a mixture of factory 2004 and 2005 banshee decals on it.  Replaced the radiator cover and tank covers with OEM Yamaha as the originals were beat up pretty bad. New bars/grips. Replaced the rear taillight assembly and stingers/silencers also.  The previous owners didn't treat it very well, so my ownership has just been bringing it back to like new condition. All the items listed above have 2 trips to the dunes on them, otherwise brand new.  I've had no problems with the quad, it runs and rides great.  I've only had it out a total of 5 times since I've owned it and thinking I should just sell it to someone that can actually enjoy it.
The only issues it has right now are a small burn hole in the rear plastic and melted side of the air box where it sat against the left side stinger.  I've put some exhaust tape on the inside of the fender and adjusted the stinger to avoid contact.  Also, the front bumper is missing.  One of the mounting holes is mangled, but the other 3 appear to be good.
Asking $2500.00 obo.  Local pickup, or can meet within a reasonable distance.
Thanks, Garrett
  • 2 weeks later...
