Wanted Shearer SB SF inframes
uman1030
I had a heck of a time looking for a set of used small bore in - frame Shearers. I ended up getting new and Jeff at F.A.S.T. took the best care of me. You should give him a call if you don't have any luck.
Sent from my SCH-I545 using Tapatalk
ya most likely what will happen spoke with him yesterday while ordering alot of other parts and this was something we talked about but i figured id check here first but most likely i will just order a set. was contemplating a set of rockets that a member has so i took a look at the dyno charts listed for the 10mm serval and i was curious what the rockets would do for a 421 serval with slighly less hp. any one have an opinion on these rockets for a 421 serval as opposed to some shearer's?
I got some sheares one out each side..lmk if u still intrested
Appreciate the response but with the type of riding I do I would destroy a set of oof's probably sooner then later. I'm going to stick with in frames.
