ATVridinMaNiAc Posted December 30, 2013 Report Share Posted December 30, 2013 Aluminum open airbox setup with pods and outerwears for me. Breathes good and protects good enough from underneath and the sides to where im not worried about puddles or anything. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 30, 2013 Report Share Posted December 30, 2013 Aluminum open airbox setup with pods and outerwears for me. Breathes good and protects good enough from underneath and the sides to where im not worried about puddles or anything. Sorry, that set-up kills power on motors like his. Also not the best set-up for really wet conditions. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 30, 2013 Report Share Posted December 30, 2013 If it'd make you sleep better you can easily fab a splash guard to fit under your pods . That'll protect them from all but the deepest mud puddles. Those aluminum air boxes are junk. You can also run a stock air box with a kn filter and proflow and mod the crap out of it. Either option is better that those aluminum airboxes. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted December 30, 2013 Report Share Posted December 30, 2013 i run .012" base gasket on mine, so do many others. run what the builder supplied. Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted December 30, 2013 Report Share Posted December 30, 2013 Definitely not better then an aluminum air box...Lmao your saying the shitty ass plastic is better? I've had them modded out with pro flow and whatnot and they blow in every way. Not every1 dunes and drags there banshee only. Alot of us can't run open pods. My aluminum holds pods and acts as a good splash shield which is why I wanted mainly and its easy as hell to remove compared to stock. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 30, 2013 Report Share Posted December 30, 2013 Definitely not better then an aluminum air box...Lmao your saying the shitty ass plastic is better? I've had them modded out with pro flow and whatnot and they blow in every way. Not every1 dunes and drags there banshee only. Alot of us can't run open pods. My aluminum holds pods and acts as a good splash shield which is why I wanted mainly and its easy as hell to remove compared to stock.<br /><br /> Yep. The stocker IS definitely better than the cfm one. But whatever blows your skirt up. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 30, 2013 Report Share Posted December 30, 2013 You can count on about a 3 hp LOSS going from a stock modded box with proflow & k&N to the CFM aluminum air box on a health 350 ish cc stock stroke motor. Probably be more on a 421 serval. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 30, 2013 Report Share Posted December 30, 2013 Definitely not better then an aluminum air box...Lmao your saying the shitty ass plastic is better? I've had them modded out with pro flow and whatnot and they blow in every way. Not every1 dunes and drags there banshee only. Alot of us can't run open pods. My aluminum holds pods and acts as a good splash shield which is why I wanted mainly and its easy as hell to remove compared to stock. Yes, SPRINKLERMAN is correct. That Aluminum set-up robs upwards of 15HP. Don't believe me?……Ask NICKISGOD. He learned it the hard way when we were dyno tuning his F.A.S.T. built 485 cheetah bike. We did all the tuning with just pods right on the carbs. Then once it was all dialed in we had him put his air box back on. MAJOR drop in power. He sold that thing real quick. Then you can ask TURBOFIREHEAD???? (Site member from Wisconson) He came down and got his stuff all dyno tuned. He was told to ditch that Aluminum air box and didn't….then proceeded to go on a trip and the air box got dunked and that motor nearly hydro-locked. Trashed his top end and he had to learn that lesson the hard way. But if your happy….that's fine. But it doesn't make the facts invalid. On a 421-465 Serval….ANY air box is going to rob the power you paid good money to get. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted December 30, 2013 Report Share Posted December 30, 2013 I don't get why some of you guys wanna mud bog with your banshee. I understand that sometimes you gotta go through some water and or mud but you don't gotta go through it at 50mph. IMO pods is the way to go and if your still worried about it do what the others said and make a little water flap. Your gonna loose out on power with either box Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 30, 2013 Report Share Posted December 30, 2013 This^^^ on my 350 trail bike with mild port, stock carbs, pro circuits, I lost 3 hp almost the whole curve. Put the stock box back on..blam! 3-4 hp came right back. That's all I needed to see. Ebayed that sucker. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 30, 2013 Report Share Posted December 30, 2013 Ebay….where all the crappy banshee ideas go to die. 1 Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted December 30, 2013 Report Share Posted December 30, 2013 Ebay….where all the crappy banshee ideas go to die.Agreed for the most part. You can find some good parts on eBay but most of the stuff isn't that great Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted December 31, 2013 Report Share Posted December 31, 2013 On the bigger engine bikes I guess I could see that but for a trail bike I doubt it'll be a loss with like a cfm box. I felt a difference first hand when making the switch but I did have to re tune the carbs to get it to run best with it though ofcourse, it seemed to help with my bottom end a lot and transition from low to mid. With where I ride I will never run open pods and if I do it will be with outwears and a splash guard under it at the least. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 31, 2013 Report Share Posted December 31, 2013 On the bigger engine bikes I guess I could see that but for a trail bike I doubt it'll be a loss with like a cfm box. I felt a difference first hand when making the switch but I did have to re tune the carbs to get it to run best with it though ofcourse, it seemed to help with my bottom end a lot and transition from low to mid. With where I ride I will never run open pods and if I do it will be with outwears and a splash guard under it at the least.<br />I tested it on my 350 cc trail bike. -3hp vs a stock air box with your standard k&n. Why spend $100.00 on something that reduces hp? Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted December 31, 2013 Report Share Posted December 31, 2013 That's crazy, but did you retune to each setup and I'm curious to where the HP was lost. Might have gained elsewhere. Sent from my MB886 using Tapatalk Quote Link to comment Share on other sites More sharing options...
