Blaster Front Brake Swap
Take the complete front brake system from a banshee,then you will need to get spindels from banshee including hub and rotor for both sides.The ball joints are the same on blaster and the shee.You need to change spindel to give youself aplace to bolt caliper to. the lug spacing is the same on front rims,so you can run blaster rims on shee hubs.Also the tie rods are the same.Just take off and put on.When installing you will figure out where all the brake lines will need to go.Lot better brakes.Or just replace the blaster with a SHEE.THE SWAP WILL WORK EITHER WAY
