87sheerips Posted December 23, 2013 Report Posted December 23, 2013 Machined / laser cut from 304 stainless steel plate and round bar Will include one extended bolt for the rear hole on clutch side, otherwise uses factory hardware. The foot location is stock position. I can custom make any position per your request. Fully TIG Welded, will be shipped raw or you can powdercoat any color below for same price. Matte black Texture black Gloss black White Metallic silver Fire red Deep blue For the pair: $160 shipped USA / $180 world Paypal: jdubswmu@yahoo.com Here is the lighter version. Uses knurled 1.25" x .120 wall stainless tubing. Also will come with a 3/8-16 nut on the inside of either end for OOF's.... Approx 1.3lbs per peg For the pair: $160 shipped USA / $180 world Quote
87sheerips Posted December 23, 2013 Author Report Posted December 23, 2013 Roughly 5 lbs per peg. Per the CAD model... I will know more next week after I get a set welded up. Quote
87sheerips Posted December 23, 2013 Author Report Posted December 23, 2013 The holes on the ends are drilled and tapped 3/8-16 for easy mounting of OOF's Quote
87sheerips Posted December 24, 2013 Author Report Posted December 24, 2013 Nice job jd!!! Thx buddy. Any ideas for modifications to these or something else bring em on... Trying to make something better for all of us Quote
m671054 Posted December 24, 2013 Report Posted December 24, 2013 The drag pwgs need more traction. maybe ball mill across the top to give it teeth. or make strips and weld Quote
n2otoofast4u Posted December 24, 2013 Report Posted December 24, 2013 6-8 kold kutter screws drilled into the top of them. Quote
87sheerips Posted December 24, 2013 Author Report Posted December 24, 2013 The drag pwgs need more traction. maybe ball mill across the top to give it teeth. or make strips and weld The lightweight tube version will be heavily knurled and should offer some good traction. The solid bar will be milled a shown in model and should be very grippy. Quote
87sheerips Posted December 24, 2013 Author Report Posted December 24, 2013 6-8 kold kutter screws drilled into the top of them. I like it! Quote
87sheerips Posted December 24, 2013 Author Report Posted December 24, 2013 The drag pwgs need more traction. maybe ball mill across the top to give it teeth. or make strips and weld Could def weld some thin strips on top of the tubes... Let me see how grippy the knurl turns out to be.... Quote
87sheerips Posted December 24, 2013 Author Report Posted December 24, 2013 Could def weld some thin strips on top of the tubes... Let me see how grippy the knurl turns out to be.... OR I could tubelaser some strips out of the tube... Would take out even more weight and add some traction... Hmm. Quote
421alkybanshee Posted December 24, 2013 Report Posted December 24, 2013 Looks a heck of a lot better than direct drive pegs ! JD, make sure these don't snap off like the competition do !!!!! I'll take a set if they will hold up Quote
87sheerips Posted December 26, 2013 Author Report Posted December 26, 2013 They will have a money back guarantee. They are over-built IMO. Quote
87sheerips Posted December 27, 2013 Author Report Posted December 27, 2013 The bar version is coming out well Quote
