southside Posted December 21, 2013 Report Share Posted December 21, 2013 On higher powered drag/dune bikes with modded frames (lightened oem) who's eliminated the lower engine stay (two links under motor) and who's running them and results of each setup. Thanks in advance for the info Quote Link to comment Share on other sites More sharing options...
Finch Posted December 21, 2013 Report Share Posted December 21, 2013 im not running them but really the more power you should have them keeps engine from twisting. Quote Link to comment Share on other sites More sharing options...
joshb Posted December 21, 2013 Report Share Posted December 21, 2013 On a drag bike I'd definitely run them. Don't want that motor twisting. With them and the "washers" between the motor mounts it'll keep it tight with little to no movement. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 21, 2013 Report Share Posted December 21, 2013 On a drag bike I'd definitely run them. Don't want that motor twisting. With them and the "washers" between the motor mounts it'll keep it tight with little to no movement. That depends on the motor and how well you're putting the power down. Our 18DMs were twisting in the frames under a load. That's why I designed the motor support. Quote Link to comment Share on other sites More sharing options...
fappy'97 Posted December 21, 2013 Report Share Posted December 21, 2013 Our 18DMs were twisting in the frames under a load. That's why I designed the motor support. But what about big motors? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 21, 2013 Report Share Posted December 21, 2013 Must run! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 21, 2013 Report Share Posted December 21, 2013 But what about big motors? You have to weld them to the frame or they will shoot out the side under load. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 21, 2013 Report Share Posted December 21, 2013 But what about big motors?<br /><br />..big raptor motors?.. not needed. 1 Quote Link to comment Share on other sites More sharing options...
possum Posted December 21, 2013 Report Share Posted December 21, 2013 Didnt know people left these mounts off. To each their own. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 21, 2013 Report Share Posted December 21, 2013 I had problems big time without them. I broke a chain without them and had popping under a good load with rippers. If you have a hillshooter running 10 paddles you can get away with it but much more than that and you will be poppin the chain. I would run them. Quote Link to comment Share on other sites More sharing options...
Finch Posted December 21, 2013 Report Share Posted December 21, 2013 ive been lucky so far. but motor doesnt see much twisting in the trailer. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 22, 2013 Report Share Posted December 22, 2013 You can get by with running 1 on PTO side only on smaller motors. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 22, 2013 Report Share Posted December 22, 2013 For what they weight……why eliminate them? That's putting WAY too much interest in lightening a machine. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 22, 2013 Report Share Posted December 22, 2013 I had a few chassis that didn't have mounts for them. I'm sure weight loss can best be found somewhere else. Quote Link to comment Share on other sites More sharing options...
