No Pressure To Front Brakes?
Sheeboy12
I replaced the front pads in the front and also disconnected the front calipers to clean them. I put everything back together and proceded to bleed the brakes. I got fluid to slowly come out of the right side. Then i tried the left. My friend and i pumped for a go 30 min and no luck. We made sure that the hollow bolts were facing the correct way, we check to make sure that the master cylinder was good too. Fluid isn't leaking any where either, it's just not getting any thing to the left side? Thanx B)
unless you have an automatic brake bleeder you will be there a while, you have to pump the hell out of that thing. the fastest way i have found without a automatic bleeder is to pull the handle off and use a extension or something so you get more throw when you are pumping it( haha that sounds funny :lol: ) anyways that seems to always work for me, good luck
