m671054 Posted December 23, 2013 Report Share Posted December 23, 2013 You run alky instead of gas. not mixed with it. I run at 32:1. make sure your oil is alky compatible. i run klotz supertechniplate. check automotive speed shops or if you have local speedway racers check with them. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 23, 2013 Author Report Share Posted December 23, 2013 Thanks, I run klotz race now, so my shop that carries it should hopefully be able to get it in. And I do understand that alcohol is ran alone(with proper mixing oil) What I don't understand is the purging, also I have been reading that when you are done your racing for the day that you drain your tank and your carbs? Is this fact? Is that what is involved with purging? Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 23, 2013 Author Report Share Posted December 23, 2013 Also I'm in the process of finding a place here in ON Canada to buy alcohol. What are some name brands of the alcohol some of you use? Vp m1, m3, m5 are comeing up in my searches? I am hoping the shop where I buy my race gas can get me some in but I need to know what I need to order. Quote Link to comment Share on other sites More sharing options...
