B.b.p builders Posted December 21, 2013 Author Report Share Posted December 21, 2013 Cheap is 100$ for 1 and 150 for the other. No they are both good working carbs, not parts. I thought that was cheap. Quote Link to comment Share on other sites More sharing options...
m671054 Posted December 21, 2013 Report Share Posted December 21, 2013 You might just be able to shut one off if they are clippard syle and havent been drilled to far. thats why i asked for pics Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 21, 2013 Author Report Share Posted December 21, 2013 And I will call him thanks guys I was just curious. Like I said I never used these before so I am real curious on how they work and tuning them and just everything about them. I will call him and do some more reading. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 21, 2013 Author Report Share Posted December 21, 2013 M671054 I did say cub in my very first post sorry, it was my mistake. This hole project was going to be a cub build, but then this cheetah motor came up and I liked it so went with it instead. Quote Link to comment Share on other sites More sharing options...
Finch Posted December 21, 2013 Report Share Posted December 21, 2013 love my lectrons defiantly call dennis hes way helpful Quote Link to comment Share on other sites More sharing options...
troyzstang Posted December 21, 2013 Report Share Posted December 21, 2013 ^^^ Me too. Won't use anything else anymore. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 21, 2013 Report Share Posted December 21, 2013 I see carnage or fouled plugs. Only one thing worse than buying used carbs. Buying non matching used carbs. Brilliant! Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 21, 2013 Report Share Posted December 21, 2013 There is no reason you couldnt use the correct matching needles and you will tune each side slightly differently anyway. In what I have seen 10 mil cheetahs could work with a single PJ no problem on gas. They arent as thirsty as say a 10 mil cub with small bore pipes or even some 4mils with a lot of timing and compression. Definately just need to make sure they have gravity float/seat setup. Big bowls would still be a wise investment as well. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 21, 2013 Author Report Share Posted December 21, 2013 Ya don't see any problem either! You can 2 pwk's from 2 very different bikes jet em the same and run them on the banshee and work great! Done it a million times! A carb is a carb, they just control the fuel in a different way? No? Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 21, 2013 Author Report Share Posted December 21, 2013 Just got off the phone with Dennis @ Packard and like you guys said, more then help full! The stress is gone these 2 carbs will be perfect! Like I thought, like any descent carb it doesn't matter what it came from, it can be set up to work with choice of application. Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 22, 2013 Report Share Posted December 22, 2013 Some people drill out the orifice on Lectrons to run alky. I'm sure Packard went over that. Those carbs are waaaayy to big to run gas on that motor. They are probably too big to run alky efficiently as well. It'll run, but be hard to tune, and probably like to bog. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 22, 2013 Author Report Share Posted December 22, 2013 Umm well that sucks !! Sure rained on my parade! What size would you suggest? I don't get it, you can take a set of 35mm pwk's and run them on a stock bore banshee, that comes stock with 26mm carbs. Guys say 39mm pwk's would be a good size for this motor well the 44's are only 5mm bigger, small difference when you compare the 26mm - 35mm. I'm not claiming to know much, I only know what has worked with my experiences, and I have 0 experience with lectron carbs, and. 0 exp. with any banshee motor over stock bore. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 22, 2013 Author Report Share Posted December 22, 2013 Also I mentioned to Dennis what I was putting these carbs on, he didn't say they were to big. I am sending the carbs to him and havinghim set them up. I wish I knew about these things, I'm not a big of wasting $. Anyone running lectrons with gas, please feel free to let me know the size of motor and size of carbs you are using. Or anyone with exp. running lectrons with gas. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 22, 2013 Report Share Posted December 22, 2013 44mm on gas? I wouldn't. Quote Link to comment Share on other sites More sharing options...
B.b.p builders Posted December 22, 2013 Author Report Share Posted December 22, 2013 That doesn't help any. Why wouldn't you? Have you ever used lectrons with gas? If so, what size? What size motor? Quote Link to comment Share on other sites More sharing options...
