rebuild lag on bottom end?
96white/red
 I just joined, site is the best thing out.  just rebuilt my 96' and had port job done. It runs like hell! ! but there is a lag when pulling out not a miss or anything like that. It cleans up and runs awesome after you get going. Starts and  idles good as well, I have rebuilt several banshees this one b/c the clutch pushrod mushroomed and would not come out . So I split the cases and fixed that .. new clutch, and top end plus port job. love the power and could ride it the way it is but would prefer to fix my lagging issue. Plugs are rich but I am running rich oil mixture 6ozs/gallon for a tankfull break-in period?  I am no carb expert so help would be great??   Thanks
Only running that mix on 1st tank for the new top end then 32 : 1.  Its not running like shit but I think  I will get some help dialing it in if it doesn't clean up after this tank is gone.     I had to hone/ clean the mainshaft out and then put the new clutch in. The quad has been sitting for ten years with the clutch pushrod stuck (my pushrod issue occurred when the clutch started slipping and tried to make it home). I read about it on this site then fixed it right. Took everything out cleaned cases and all new seals. Guess I will try some lonestar A-arm next. thanks
Try one size up on pilot. Maybe your lean on the bottom end.
  • 2 weeks later...
