RagunCajun Posted December 21, 2013 Report Share Posted December 21, 2013 Need 6th? If not, n-down 1-5th dunable is the best option IMO. I took mine out for a pro mod. I'm sure ill miss it from time to time. 1 Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 23, 2013 Report Share Posted December 23, 2013 Any of you guys that get a duneable need to make sure to balance/adjust your springs correctly so as to have your "duneable" be safe and rideable as well as backloaded occasionally albiet not backloaded hard. Google "duneable override spring balance and adjustment" for a full write up and pictures explaining it. I posted it on a couple forums but pics wouldnt work on here. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 23, 2013 Report Share Posted December 23, 2013 Any of you guys that get a duneable need to make sure to balance/adjust your springs correctly so as to have your "duneable" be safe and rideable as well as backloaded occasionally albiet not backloaded hard. Google "duneable override spring balance and adjustment" for a full write up and pictures explaining it. I posted it on a couple forums but pics wouldnt work on here. This is dumb. Just buy a duneable from a builder that has proven transmissions out there. I've been running them since 2005 and have never had a failure and never balanced or adjusted any springs. There is zero reason to have to research this. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 23, 2013 Report Share Posted December 23, 2013 Tyler, If I remember Cam discussed dune ables not long back. He urged against back loading them, which some people think a dune able is capable of doing this without issue. I think he even made mention that no override is truly dune able I think what he said was that if you can't change your own shift forks, then you should NOT run a duneable override. Obviously I don't think you should go out and purposefully try to fuck one up. I have been running Redline duneables since 2005. I've had them in a 10mm Cub, 10mm DM and three 18mm DMs. I have NEVER had a failure. I am not exactly easy on them either. Quote Link to comment Share on other sites More sharing options...
Twostroke Junkee Posted December 23, 2013 Report Share Posted December 23, 2013 that hillbilly from sweethome knows how to cut duneables, i would go to him. Quote Link to comment Share on other sites More sharing options...
joshb Posted January 6, 2014 Report Share Posted January 6, 2014 Usually when someone mentions trails that's your first sign that a pro mod tranny would probably be better suited for you. No one is saying you can't trail ride an override but why have to worry about it at all? What do you mean by people just build stuff different down there? Quote Link to comment Share on other sites More sharing options...
oldskool Posted January 10, 2014 Report Share Posted January 10, 2014 You need a trailable override and 6th gear for those trails Quote Link to comment Share on other sites More sharing options...
04_blu_shee Posted January 10, 2014 Report Share Posted January 10, 2014 (edited) I run A WCR Dunable...If I were to buy another Duneable, I would stay clear from Greg.But on another note the Post that Radar is referring too, its Golden. Edited January 10, 2014 by 04_blu_shee Quote Link to comment Share on other sites More sharing options...
Grey Posted January 13, 2014 Report Share Posted January 13, 2014 Trails and override should not be used in the same sentence. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted January 13, 2014 Report Share Posted January 13, 2014 ^ Then i been doing it wrong for years. Good thing i dont let others tell me how i should set up my bike. Quote Link to comment Share on other sites More sharing options...
joshb Posted January 13, 2014 Report Share Posted January 13, 2014 Here we go^^^. Same old shit. Just because he said you shouldn't doesn't mean you can't. If you like your trail bike setup with an override then good for you. Glad it works out fine. 1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2014 Report Share Posted January 13, 2014 I just think it's funny that the actual builders will tell you not to run an override in the trails... but he must know something we don't.. Or maybe he doesn't downshift Who said you can't downshift an override? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2014 Report Share Posted January 13, 2014 You're telling me I can go from 6th-high 4th in and out of the throttle with an override? If so, I need to call your builder again. I've downshifted a lot of regular overrides in other people's bikes. I've ridden countless bikes at the dunes and completely forgot that they had a regular override. I would downshift from 4th or 5th still going really fast. It can be done. The duneable is even more forgiving and yes, I upshift and downshift with and without the clutch at all speeds all the time. No builder is going to recommend an override for the trails. Redline will not even recommend a duneable if you aren't capable of changing shift forks. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2014 Report Share Posted January 13, 2014 Ok, but I'm not talking about doing this once every blue moon, it seems that's what you think I'm getting at... A trail bike, as you know is constantly shifting up and down, shifting down into high RPMs and getting in and out of the throttle through a twisty trail or fire road.. You think an override would work for that? I thought you were going with a pro-mod? That's all you really need. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2014 Report Share Posted January 13, 2014 No builder is going to recommend an override to you. I've been running RL duneables since 2005 in about 6 different motors and never had a failure. You need to work on your reading comprehension.. The duneable is even more forgiving and yes, I upshift and downshift with and without the clutch at all speeds all the time. Quote Link to comment Share on other sites More sharing options...
