tdod101 Posted December 15, 2013 Report Share Posted December 15, 2013 (edited) Right carb over flow tube leaks fuel when running, floats seem to be set properly, don't know what else it could be.... Edited December 15, 2013 by tdod101 Quote Link to comment Share on other sites More sharing options...
1CrazyBastard Posted December 15, 2013 Report Share Posted December 15, 2013 Right carb over flow tube leaks fuel when running, floats seem to be set properly, don't know what else it could be.. Well sounds to me like one of three things either the float is "not" set properly , there is trash / debris under the needle seat holding it off its seat and causing the fuel to continue to flow or the needle itself is worn and needs to be replaced . Quote Link to comment Share on other sites More sharing options...
tdod101 Posted December 15, 2013 Author Report Share Posted December 15, 2013 Hmmm. Okay good advice, I will check all 3 tomorrow, (double check float level) Quote Link to comment Share on other sites More sharing options...
possum Posted December 15, 2013 Report Share Posted December 15, 2013 seat is dirty Quote Link to comment Share on other sites More sharing options...
joey83 Posted December 15, 2013 Report Share Posted December 15, 2013 Shake the float and make sure theres nothing sloshing inside of it. It can only be- needle, seat, float, or float height. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted December 15, 2013 Report Share Posted December 15, 2013 Pound that shit with a hammer. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted December 15, 2013 Report Share Posted December 15, 2013 Pull the floats outs and use a q tip and toothpaste to Clean the seat then make sure there is no grooving or wear on the float needle. Then set the floats to 21mm Quote Link to comment Share on other sites More sharing options...
tdod101 Posted December 15, 2013 Author Report Share Posted December 15, 2013 Thanks for the help guys, used the q tip trick, there was a bit of sand stuck in the seat so I gave it a cleaning and it doesn't leak anymore, Sweeeet Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted December 15, 2013 Report Share Posted December 15, 2013 Glad it worked for you Quote Link to comment Share on other sites More sharing options...
