jbooker82 Posted December 18, 2013 Report Share Posted December 18, 2013 You need to get an oring kit from trinity because I don't think the cool head o ring kits work on theirs. Their domes go over / around the studs. If the head has been on there that long it could happen to have the regular o rings. I would probably pop the head off first and see. Quote Link to comment Share on other sites More sharing options...
Wakendune Posted December 18, 2013 Author Report Share Posted December 18, 2013 Tapped the domes out. They are 19's. Just two O rings? I was expecting more. Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted December 18, 2013 Report Share Posted December 18, 2013 thats a pretty damn clean 87, looks like its hardly been used, pistons look new, you are LUCKY to be able to get the head sorted now before shit grenades on a ride. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 19, 2013 Report Share Posted December 19, 2013 That it one OLD ASS Trinity head. Pre-Oring. That model uses a head gasket. The newer stuff has O-rings at the dome bases as well as the outer water jacket. Those domes are a total joke. Pure marketing ploy. Clean that thing up and pass it on to some eBay fool. Then get a new head and dome combo and you'll be on the right track. Quote Link to comment Share on other sites More sharing options...
Wakendune Posted December 19, 2013 Author Report Share Posted December 19, 2013 Thinking of a chariot head and keeping the 19mm domes. What would you recommend for dome size? I don't mind burning 110 as long as it's worth it. I want the most bang for the buck. It will be a duner not a dragster or racer. It will only go as fast as my balls allow. Quote Link to comment Share on other sites More sharing options...
Wakendune Posted December 19, 2013 Author Report Share Posted December 19, 2013 And reliability is big since the reason for this change is because of poor reliability. I'll be pissed if I blow a head ring with a new head. Guy swears he never had a problem with heads. Head is almost 20 years old. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted December 19, 2013 Report Share Posted December 19, 2013 Well it's entirely possible that he's right. It's possible that the carbs were gummed up and your motor went lean on one or both cylinders. That will cause detonation and detonation can blow your head gasket. I would still ditch that head and dome combo. Those "Turbo groves" in the dome don't cause a power increasing swirl….they just become thin heat sinks that hold heat and aid in detonation. (Jetting the motor really rich fights that….but also scrubs about 10HP) If you wanna get a new head and domes in a 19cc size and check your compression, I'm sure you'll be on the right track. But keep in mind….any time an issue comes up that causes the motor to stop working properly…..you gotta verify EVERYTHING before you go WOT again. Go thru the carbs and make sure ALL the fuel circuits are clear, check that the flywheel didn't move on the crank, fresh plugs, verify what your timing is set at, if it's higher than +4…Know what that means, etc…. Your the new owner and pilot of this toy. Think of it like a wild tiger…..Know what to feed it and what it needs because if it's unhappy….your the one getting bit. (In the wallet) Quote Link to comment Share on other sites More sharing options...
Wakendune Posted December 19, 2013 Author Report Share Posted December 19, 2013 Still not convinced that it was a head gasket in the first place but at least I'll be able to be 100% sure from here on out. I'm sure I will have plenty more dumb questions down the road. Have a 5 day trip planned. Hopefully there's enough time to get everything back together the right way. Won't rush it, there will be plenty of toys available. I will report back after New Years. Quote Link to comment Share on other sites More sharing options...
