Problem with the ASV lever C/5 series
Banshee SE
I use 2 toggle switchs for the headlights mounted to a piece of aluminum under the seat. It bolts down on top of the fuel tank mounting bolts. I did get ones with a rubber cover to keep water out. Then just use a CR honda style kill switch on the handle bars. It will plug right in to the factory wireing harness.
Edited by jbooker82
I would go get a couple stainless button head allen screws. Then cut it down a little at a time until you get the clutch lever reach you want with the bolt threaded al the way in.
I already check I did not find any that can fit in the lever. I have the one that came with it maybe I'll try this later, don't have a good tool to cut it.
