Idles Runs Strong But Now It Wont Die.
bignasty1
okay well i got the thing to idle finally it does that great got it jetted pretty much as spot on as i can with these nutty temp changes and i found out it doesnt die when i hit either one of the 3 ways to kill the motor so i gotta stall it to get it to shut off... my teather kill switch doesnt work my key switch doesnt work and my stock kill switch doesnt work where could the problem be at?it still runs starts and al the other bs but it doesnt die. ohh and i just bought a set of lazr lights what do i do to install them do they hook up just like stock or do i gotta cut shit up and connect things. l8ter blake
Sounds to me that one of the ground wires (black/ white striped) is disconnected. There is one by tthe gas tank coming from the handlebars, and one on the side of the air box going to the back.
BTW, keep flaunting!!! :D
okay i found the wire but my prob is that its comin out of the black box under the seat behind where the air box would be and its disconected inside the white connecter what do i do? and i like flauntin my dumbassness i love it to. dont ya just hate those nice big ol booties damn soft skin and tasty fur bergers.
hmm......booties :rolleyes: ......soft skin :rolleyes: .......tasty fur bergers :rolleyes: .............oh ya, you need to connect those wires...check the one going from the handlebars to just in case.....you need a ground to kill the motor. You don't have one.....
yeh my problem is i cant connect them the wire is broke off flush with the end of the plug its self i cheched every where else every thing is okey dokey just thats my only problem. the wire isnt long enough to where i can connect it again the lil boogers kinda frustratin me. i wish they sold that kinda fur berger at burger king.
Right on !!!!! Nothing like getting it to Go!!
Not sure I understand which wire that you're saying is too short. If your talking about a ground end that just needs to be grounded, then you can just attach it at any bolt on the frame. Chip away a little paint if need be to get a good connection. If your talking about the wire to one of the switch harnesses being to short then just grab some wire of the same gauge (wire thickness, not the insulation thickness) from a hardware store and splice it on. Depending on how good a job you want to do, you can just twist the wires together and wrap it with electrical tape, or you could put a wire nut on the splice, or go all out and solder the wires together and apply heat shrink tubing to seal it up and make it look professional.
if you have a solder gun slder that shit so it won't be a problem again. Soldering wires is easy as pie. Jsut make sure you heat up the wires and touch the solder to the wires not the other way around. Heatshrink over it will make it look nice and keep it protected.
