Putting cases back together , not sealing right
Check all of your half moon bearing clips. Ensure they are seated in the tranny bearing and that they are seated in the grooves of the case. The large bearing on the sprocket side has a tendency to not line up and you have to move it gently to the left or ride side to allow it to seat. The half moon clip should be in the bottom case. Ensure that the ends of the clip are level on both side and not extending above the deck of the case half. Check this and see of it's the problems
  • Like 1
is the gap still there after you tq'd all the bolts??  was it ever running before?  did it have a massive rear oil leak?  if the cases are ok there is some kind of misalignment. NO amount of internet questions are going to fix that for you.  you need to look for the problem
