cold weather issue
foxrider603
So im having some issues. It seems im having a mid throttle bog once it hits powerband its good not sure on what i should be doing new to jetting. My shee is completely stock other then fmf exhaust. Im running 270 mains with 27.5 pilot needle on 2nd clip on bottom and a little more then 2 an a half turns out on my air/fuel screw. Im 500ft above sea level and the temps range from 40 degrees and lower
have you tried turning the air screws in to 2 or 1.5. when you say stock do you also mean air box? or you running open airbox with lid off or pods etc?
with just pipes and no airbox mod 270 should be fine. his issue wasnt at wot from what i read so main size shouldnt be a factor in his issue. just my opinion anyways. try the air screws, maybe richen needle if it persists?
is it a bog or falling off totally could be too rich on needle also.
Not to say that the main shouldnt be increased but it doesnt sound like thats whats causing the issue at hand.
I ran a similar stocker with 280main  30 pilot only pipes and needle was best at stock position still even at 10-20ish deg. at 1.5 on air/fuel screws
edited above post. have you just tried setting air fuel screws by ear? making sure they are the same but listening to the engine to achieve the right setting?
