Help With Fox Floats
mysterion
I have some Fox Floats(no rezzie) that are giving me trouble.  When I compress the front end, they barely rebound. The front end just sits there and sags. The shocks do not have that much ride time on them.  I have tried pumping them up with more air and no luck.  What could be the issue? Thanks for any input.
  • 3 weeks later...
I bought a brand new set a while back will similar issues. Air them up and come back out an hour later to the bike sitting on the ground. Tried more air etc. with no luck. I ended up pulling the shrader (air) valve out and found that the o rings were faulty. Replaced the o rings and haven't had an issue since. It's air and the slightest hole will let them leak. Worth a shot. Hope it helps.
