Best Swingarm Length
raxen
What is the best swingarm length for trail riding? I know that the -1 is supposed to correct the banshee suspension geometry to be more like a 250R but is that something that you want. I have never ridden a 250R, only banshees. I know for mountain climbs 8-10+ is the way to go, it has looked ditto for drags but what about dunes and trails?
The whole point in lengthening the swingarm is to transfer weight. When you're drag racing you dont want to wheelie to the moon when you take off, so you lengthen the swingarm so you have a better takeoff, the disadvantage to doing this is that it makes it harder to maneuver and you have less traction. When you shorten the swingarm you get more traction and it is alot easier to maneuver. Deciding which way to go really depends on your type of riding.
Well,
I just bought a 10 mm crank
accompanying cylinders
nitrous wet kit
adj. timing plate
IV heads
lightened flywheel
shift star mod
I haven't bought carbs or pipes yet
Pretty radical port work
V-force reed assembly
I am waiting to buy the pipes and stuff after my walet recovers from the 10 mm crank. The nitrous just looked fun, I've drag raced before with nitrous and it looked to be a whole load of fun on a banshee.
:unsure: and your gona ride trailes and dune
if its on gas i would say your gona need probably a +6 or +8
don't even think about running a minus 1 it would flip over at idle not to mention when you give it some juice
get us some pictures of that beast when its all done
I'll get some pics up soon. The frame just got in from the powdercoater and I just purchased a T-Rex kit for the motor. It will be sweet one day.
I run a 4 inch on my shee at the Dunes in Idaho.Your bike sound like you are going to make alot of power and if you are more into dune or dragging I get 8" ext swing. I sure with N20 you will need it. If you plan on trail more than dune i think 4".I like mine alot, It don't seam like i need to force it around the few trails i do use it on.
thanks, I was thinking about the RAX titanium after the suggestions. I think right now it only comes in 6 inche ex. lengths.
