xslice Posted December 4, 2013 Report Share Posted December 4, 2013 I have searched the common suspects on line and all show but none seem to list the "inner cap" that fits under the outer cap of the throttle valve assy. Purchased a used 2002 and found that flat alignment tab that fits along side the flat spot on top of the carb is broken off. It is part #7 on pg.191 of Clymers. Any help on locating one would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted December 4, 2013 Report Share Posted December 4, 2013 Are you talking about part of the TORS box? Spend the time and money to get rid of that crap. Do a TORS delete with carb tops, cable, and idle speed screws. Quote Link to comment Share on other sites More sharing options...
xslice Posted December 4, 2013 Author Report Share Posted December 4, 2013 Are you talking about part of the TORS box? Spend the time and money to get rid of that crap. Do a TORS delete with carb tops, cable, and idle speed screws. That is what I am doing- getting rid of the TORS. Don't I still need that inner plate on top of the spring with the flat tab that slides down along the flat portion of the carb throttle valve housing or does that part go away with the TORS deletion? Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
killer454 Posted December 4, 2013 Report Share Posted December 4, 2013 I think I have a junk but complete blaster carb in the garage but I bought my maual off internet so need a picture of the part you pay shiping I will send it to you for free if I have it. I think the blaster carbs are the same but not sure it has the tores on it to. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted December 4, 2013 Report Share Posted December 4, 2013 That is what I am doing- getting rid of the TORS. Don't I still need that inner plate on top of the spring with the flat tab that slides down along the flat portion of the carb throttle valve housing or does that part go away with the TORS deletion? Thanks for the reply. Nope, don't need that part. Replacement carb top screws directly onto the carb, with no other plate. 1 Quote Link to comment Share on other sites More sharing options...
xslice Posted December 4, 2013 Author Report Share Posted December 4, 2013 It's the part between 19 and 26 that doesn't have a number. http://images.cmsnl.com/img/partslists/yamaha-yfz350a-banshee-1990-carburetor_bigyau0300a-11_25b5.gif Quote Link to comment Share on other sites More sharing options...
Starwriter Posted December 4, 2013 Report Share Posted December 4, 2013 Don't need that part with a TORS delete. 1 Quote Link to comment Share on other sites More sharing options...
xslice Posted December 4, 2013 Author Report Share Posted December 4, 2013 Don't need that part with a TORS delete. Thank you again! Quote Link to comment Share on other sites More sharing options...
Starwriter Posted December 4, 2013 Report Share Posted December 4, 2013 Thank you again! Glad to be able to help. Quote Link to comment Share on other sites More sharing options...
