Mikuni vs kehin
JDP421
PWK's are definitely easier to make adjustments to.
But Mikuni's can be swapped from Gas to Alky and back without issue. Once the PWK's get set up for Alky, that's pretty much it.
Cameron likes the PWK's and if you stick with them he can probably advise you on jetting your 7 mill.
Did u have to press a new throttle needle passage into the carb ?
Short of actually machining a "tube" or "Sleeve" that's the only way it can be done.
PWKs have that tube pressed in.
I've also heard of others doing the same...but, for the price of PWKs, it's easier, IMO...to buy another set.
That being said, also...there's not many out there going from gas to alky and back to gas.
A while ago, if you had a PWK drilled for alky, people just considered them done.
With some work, you can replace them.
In my own opinion, though....because of how cheap you can buy used carbs, it's not worth it.
