banshee shift issue
chads300
I acquired a 1987 banshee a couple months ago and work picked up so its been setting in the corner...has basic bolt ons  like exhaust filter, nerfs  ect. well I am ready to start figuring out what the problem is.... the bike wont shift at all if you try and shift it normally but: if you put pressure on the shifter(push shifter in towards motor to get pressure on it) it will shift perfectly fine. any ideas would be great
splines are good shifter is tight.....the idiot I got it from was going to use it as a "parts" bike for his other banshee........upon looking at the quad I spotted the reason why it would not star(disconnect choke crossover tube) so I bought it for $850. I should've worded it better in my first post if you play around with it it will sometimes shift but if you put pressure on the shifter it will shift perfectly threw all 6 gears
Thanks, look for wear grooves in both. Also for wobble in the shift shaft claw pivot. The shaft shouldn't move when you put pressure on it. If it does the shaft could be worn and the white bushing that holds it from sliding to the left, the cover has a bung on it that holds it from sliding to the right. All things to look at.
You can also take a piece of straight stock, about 1" by 6" and drill two holes in it corresponding to the two lower left screws in the side cover, then when the cover is off, bolt that piece on to mimic the spot on the side cover that usually hold the shift shaft in. That way you can shift it and see what is going on. Not running of course, and will need to be spinning the back tires.
